void setup() {
winsenBegin();
Serial.begin(9600);
void loop() {
float result = winsenRead();
Serial.println(result, DEC);
Setup the Winsen sensor
void winsenBegin() {
Serial1.begin(9600);
byte setConfig[] = {0xFF, 0x01, 0x78, 0x41, 0x00, 0x00, 0x00, 0x00, 0x46}; //Set 1 Q/A configuration
Serial1.write(setConfig, sizeof(setConfig)); //
delay(1000);// Wait for a response
while (Serial1.available() > 0) { // Flush the response
byte c = Serial1.read();
Read the sensor
@return {float} sensor [C]
float winsenRead() {
byte petition[] = {0xFF, 0x01, 0x86, 0x00, 0x00, 0x00, 0x00, 0x00, 0x79}; // Petition to get a single result
byte measure[8] = {0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00}; // Space for the response
float ppm;
Serial1.write(petition, sizeof(petition));
delay(2000);
if (Serial1.available() > 0) {
Serial1.readBytes(measure, 9);
if (measure[0] == 0xff && measure[1] == 0x78) {
if (measure[0] == 0xff && measure[1] == 0x86) {
ppm = (measure[2] * 256 + measure[3]) * 0.1; // this formula depends of the sensor is in the dataSheet
} else {
ppm = -1;
return ppm;
