hi,
i want to programme atmel 89s52 just using serial coomunication...no ISP programmer..
just At89s52->MAX232->PC...
this connection can programme the chip..As well as use for Serial communication..
is this possible?????????????
plz reply???????????????:roll::roll::roll::roll:
The AT89S52 does not have In-Application Programming feature. Main part of an bootloader is flashing in runtime. The only solution that I see is to use an external flash.
For the AT89C51ED2 I use atmel's program called "FLIP". I create a batch file and just double click it to program the device with batchisp.
Easiest way to program the chip. Just install a jumer on PSEN to GND, and click the bat file. Easy.
hi,
