buffallo
I am sort of a newby in RF and as for beginning I want to test a simple Tx-Rx circuits at (let's say 27MHz). For this purpose I am designing a transistor-driven oscillator with a fixed frequency and I use a λ/4 monopole antenna to emmit the non-modulated signal. However, I have a 'problem' with the detection of this signal.
Even worse - how could I know if I am actually generating and emmiting any signal, if I can't detect it? (assuming I don't have a Hi-Freq oscilloscope or spectrum analyzer).
For now I am reading and deciding on simpe Shottky diode AM detector, consisting of a capacitor and resistor. The receiver antenna is connected to the resonant tank circuit and the signal for the detector is obtained from it.
Running simulations with LTSpice (modelling the antenna as a voltage source with fixed frequency, voltage of 20uV an impedance of 36 ohms) the output of the detector does not show any signs of detecting anything.
My question is what are the typical values of the intensity of the field (i.e. voltages across inductance/capacitance in LC tank circuit)? What are the minimum signal voltages a typical shottky diode can detect and can biasing the diode help in any way to improve sensibility of the circuit?
I hope this thred would turn into a constructive discussion.
Thanks,
Dimitar
Thanks,
Dimitar
