Type of Transformer used in DC to AC inverter.
DBK1972
Newbie level 1
transformer used in inverter
Hi, Can any1 tell me what is the difference betw'n using centre tap transformer and without tap transformer, in DC to AC inverter.
h bridge and centre tapped inverters
Hi
It is mostly depend on the drive circuit
most inverter use push-pull circuit and center taped transformer is the best solution
All the best
Bobi
dc to ac centre tapped
Center tapped push-pull is the most simple circuit with least switching transistor count. H-bridge however has the advantage of easily recovering the leak inductance energy to the primary side, although it involves more switches and possibly higher on-state losses.
advantages of half-bridge dc to ac inverter
Centre tap is used for pushpull topology. For Full bridge topology, center tap is not used. This is for Linear System.
In s.m.p.s. system, center tap is used for Push pull topology and not used in flyback/forward/half- bridge/full bridge topology. These are all for input to the Transformer. OUtput winding is optional.
Tapping is made to differ voltage in input/output of the transformer.
