two timer simultenously lpc2148
embpic
Advanced Member level 3
india
Hello master's
i am using lpc2148 and keil 4. i had done this two timer simultenously and works well but now i tried by configuring newly and copy pasted last also but this program not working.
in debug mode it works well but on dev. board it does not work.
here i have posted files.
if i do all this in single file then it works on dev. board then what should be the problem with seprate files.
  • files.zip
The problem is in the red lines, you overwrite the VICIntEnable register
void init_timer()
	T0CTCR = 0x00;
	T0TC   = 0x00000000;
	T0MR0  = 0x00003b2f;
	T0MCR  = 0x0003;
	T0TCR  = 0x01;
	VICIntSelect  = 0x00000000;
	[COLOR="#FF0000"]VICIntEnable  = 0x00000010;	[/COLOR]
	VICVectAddr0  = (unsigned long)isr_t0;
	VICVectCntl0  = (0x00000020)|4;
__irq void isr_t0(void)
	T0IR = 0x01;
	IO1PIN ^= (1<<16);
	VICVectAddr = 0x00;		//acknowledging VIC controller...
void init_timer1()
	T1CTCR = 0x00;
	T1TC   = 0x00000000;
	T1MR0  = 0x00003b2f;
	T1MCR  = 0x0003;
	T1TCR  = 0x01;
	[COLOR="#FF0000"]VICIntEnable  = 0x00000020;	[/COLOR]
	VICVectAddr1  = (unsigned long)isr_t1;
	VICVectCntl1  = (0x00000020)|5;
__irq void isr_t1(void)
	T1IR = 0x01;			//clearing interrupt register...
	IO1PIN ^= (1<<19);
yes sir but i think this was not problem. problem was
	PINSEL0 = 0x00;
	PINSEL0 = 0x00;
	PINSEL0 = 0x00;
which should be as
      PINSEL0 = 0x00;
	PINSEL1 = 0x00;
	PINSEL2 = 0x00;
and it works.
VICIntEnable = 0x00000010; enables the timer0 interrupt and VICIntEnable = 0x00000020; enables JUST the timer1 interrupt and overwrites the timer0 interrupt bit.
Apparently this was not a problem for you because you didn't try to use the interrupts but it will become a problem as soon as you try to use them.
sir i am not getting bcoz i m using interrupt.
do i need ORing with this Reg. you shown.
is it like
VICIntEnable  |= 0x00000020;
Yes, you need to OR the values, VICIntEnable controls which of the 32 interrupt requests and software interrupts contribute to FIQ or IRQ so if you want to use more than one interrupts you either need to OR the bits or write the register one time with the value of the combined bits
For example for the two timer interrupts, either
VICIntEnable  = 0x00000010;  // assuming this doesn't overwrite a previous interrupt setting
/or
VICIntEnable  = 0x00000030;
