Munib
What is the basic difference between double sided PCB and 2 layer PCB?
Most of the RF modules require the 2 layer PCB with one complete layer acting as groung plane.Can i use a double sided PCB the same way as one side will be acting as ground plane and other side will have the components.
Whether both kind of implementation will give same results if not then what kind of difference there will be?
Note: Frequency of RF modules is 418 MHz
