cnm
Full Member level 2
For bias line choke design, I am trading between using two small spiral inductors in series vs. one large spiral inductor. Any one has any comment on the pros and cons between the two approach?
This depends by a lot of factors as frequency, layout, afferent decoupling capacitors (or u-strip stubs), etc.
Sometimes to get wideband chokes I put two ore more inductors in series (e.g. 10nH + 100nH + 1uH; the inductor closest to the source has the largest inductance and the inductance closest to the load has the smallest inductance).
When is about expectations always I have a doubts.
There is a famous quote of Albert Einstein, which generally is guiding my way: "The only source of knowledge is experience".
Not sure what to make of your reply but a 1uH choke ceases to be a 1uH at high frequencies and (depending on construction) it can look like a capacitor up at UHF.
This capacitor then resonates with the series 100nH + 10nH and you don't have a choke at that resonant frequency any more, you actually have a poor quality acceptor circuit.
That's why I asked if you actually have found real 10nH + 100nH + 1uH components that actually work in a group. I've seen engineers simulate a string of chokes using s parameters but when they actually test it for real there is usually a resonance that spoils the performance at one or more frequencies.
Can you give a part number of the 1uH you used? Is it a secret part that you don't want to share?
I think the OP may have similar issues with two spiral inductors in series. There could be a resonance that spoils the wideband performance.
Note that if the bias choke is used in the output of a high power transmitter (eg >20W) you only need to have a very faint resonance (seen as a very small and narrow dip in S21) in the series chokes to transfer enough power to destroy the bias choke(s).
It is tempting to use two different sized coils for broadband applications. That way you get two different SRFs, and one coil can be a large one for filtering out the low frequencies. I would either space them out, or layout at right angles so one's magnetic field does not couple to the other one.
The do have conical inductors that work better for large bandwidth applications. See Piconics.
I've never tried stacking two spiral inductors but I'd imagine the results will be poor for the reasons I gave earlier.
I'm assuming you mean microstrip spiral inductors? These are effectively a spiralled transmission line so if you put two (different sizes) in series then at some frequency point(s) one is going to be looking capacitive and one is going to look inductive so there will be an acceptor response somewhere in the frequency band. So the result will not be broadband.
Can you define the frequency band you are considering and also what bandwidth you want it to work over?
---------- Post added at 17:23 ---------- Previous post was at 16:52 ----------
Where I work we did try playing with the Coilcraft conical inductors for use as a bias tee. The s parameter files do look really encouraging but when you actually test one on a VNA then you see lots of internal resonances. These are typically only a fraction of 1dB but for our purposes this was no good. You don't see these resonances on the simulation because the s parameter data is coarsely stepped every 50MHz
I've yet to find a better bias tee choke than the old miniature axial chokes that date back to the 1980s. eg 1uH can work extremely well to beyond 3GHz. We did try adding smaller chokes in series but this generally spoils the performance below 3GHz due to small resonant suckouts etc.
I think it depends on what you want from the bias tee. The conical chokes are going to be fine for many users as the small resonances are insignificant to most people. We had a flatness spec that was very strict over any small subset of the band so it failed where the resonances were. However (from memory) the resonances were very small wrt 1dB.
I don't think you will cover LF to 10GHz with a set of spiral inductors!
Is the LF-10GHz for a low level amplifier? If so then I guess the Mini Circuits UWB choke forms a benchmark over 50-10,000MHz.
https://www.minicircuits.com/pages/s-params/ADCH-80A_GRAPHS.pdf
However, I rarely design stuff for more than 3GHz and I have a good 1uH bias choke for this range. I also have a reasonable 3GHz VNA at home so I suppose I could start the ball rolling with a design that doesn't meet your spec but still performs well!
I'll post up a plot of my favourite 1uH choke. Note that this is 'slightly' cheating as I'll just fit the choke in shunt on a test fixture rather than plot a proper bias tee. So no series DC block caps to spoil the response.
Is it permissible to use shunt reactance in the bias tee? eg series L, shunt C, series L, shunt C etc?
Edit:
Here's a plot of the 1uH over LF to 3GHz.
As you can see it performs very well. The plot is taken on a test fixture and this has precision 20dB pads included in the calibration in order to reduce ripple due to test equipment limitations.
As you can see there are no suckouts anywhere and the choke stays nicely reactive with no measurable resistive loss anywhere
I can't measure beyond 3GHz here at home but I do know it lets go above 3GHz so it won't meet your 10GHz spec. But it is very good for work up to 3GHz.
Click on the link below to access the doc with the plot.
Yeah, I met lot of people that never tried something but they have doubts, because they are stuck in theory. In fact, unfortunately, I live with them everyday.
Different inductors in series, or conical shape choke, or logarithmic type winding choke, (all of these approaches for increasing bandwidth) are used in microwave circuit design by more than 50 years. There are tens of patents about this ideas.
I've certainly tried stacking lumped inductors in series and that's why I offered my experience on this.I met lot of people that never tried something but they have doubts
I also meet people like you where I work but not every dayIn fact, unfortunately, I live with them everyday
Are you having a pop at me?
Show me how you can stack two inductors without introducing small resonant suckouts. Sure. you can extend the bandwidth but there is a price to pay. Take a look at the plot of my 1uH bias choke. It looks GOOD. If I try and extend it by adding a 100nH in series then It will lose performance in the 20-3000MHz range due to suckouts.
You still haven't given me an example of your own 1uH choke + 100nH + 10nH.
"If I try and extend it by adding a 100nH in series then It will lose performance in the 20-3000MHz range due to suckouts" - why is this? I thought 100nH has a much larger SRF beyond 3GHz?
It's because at UHF the 1uH choke is no longer a 1uH choke. At UHF and higher it's reactance will be somewhere on the outside of the smith chart and at one frequency it will have capacitive reactance that will resonate with 100nH and suddenly you have a small capacitor in series with 100nH at that frequency. Usually this doesn't mean a deep suckout resonance as there is high ESR in the resonance but it can mean a 1dB dip in the response.
I'll stick a handwound 100nH choke in series with the 1uH choke and plot it over 3GHz. Give me a while to do this...
Edit:
Yes, I was plotting S21 of a short run of microstrip on Rogers 4003 PCB material with the choke in shunt. Obviously this doesn't represent a thorough test of the choke but it is OK for a quick test. At work we have proper test fixtures and multiport VNA capability but I only have a basic VNA.
Here's a doc with what I see on the VNA with the 1uH and 100nH in series. I've taken plots with both orientations of the two chokes. eg 1uH + 100nH and also 100nH + 1uH.
I get suckouts with both ways of connecting them although the suckouts are layout sensitive and move with respect to height above the PCB. You can see than in both cases the 20-3000MHz performance is degraded. Sadly the 3GHz VNA can't show if the performance improves above 3GHz.
Maybe I'll try 100nH 1uH and 10uH to scale everything down in frequency.
To think this further, I am wondering if it is always true that one spiral is better than two spiral in series for building bias chokes?
