Register Log in
Two scale factors in IMU
senmeis
an IMU has two parameters:
scale factor repeatability = 1000 PPM (1-sigma)
and
scale factor in-run stability = 250 PPM (1-sigma)
Question: What is the difference between them?
Senmeis
wwfeldman
Advanced Member level 2
from https://en.wikipedia.org/wiki/Inertial_measurement_unit
repeatability is getting the same result from doing the same thing - say you use your IMU to fly a plane from dallas to tokyo
do this several times. the repeatability is a measure of your landing in the same spot each time
stability is sitting still and getting the same thing - say you park your plane in denver, and leave the IMU running. stability is it saying your still in the same place
senmeis
I’m not sure if the „scale factor in-run stability“ is related to the case when the IMU stands still. Attached is an example of both parameters. It seems scale factor in-run stability is measured with the roll = 180 degrees.
Senmeis
Toggle Sidebar
