Two memories with different values in Verilog HDL
vivek_p
In my design I want to use two (2) identical memories. I have written a code for the memory in Verilog HDL.
Say my module is "mem.v"
// Instantiation
mem m1 (port lists);
mem m2(port lists);
I have instantiated the memories as above. I want to initialize the two memories with different values. How can I do it without creating two copies of the memory, I mean say "mem1.v" and "mem2.v".........and initialise it independently.
Please help me.....Urgent
Re: Memory - help required
What about initializing them by a code u run at the start of the simulation?
Amr Ali
Can u please explain it in detail with an example
I did not code in verilog long time ago, I cant show an example. I will look for one.
My idea is to write a function the loads data into each memory at reset.
Amr Ali
But can a function be synthesised using Xilinx or Synopsys
A function and procedure can be synthesized but why do you need to initialize a memory at run time?!! That's usually the task of the boot loader.
Amr Ali
    vivek_p
Can anyone post a sample code???? Please
This is how I would do it. Since you wrote mem.v yourself, you can add the init routine inside there as well.
For example:
// mem.v
module mem;
reg [7:0] mem_array[99:0]; // memory array
task init;
input [200*8-1:0] data_file; // 200 max chars for data file name
$readmemb (data_file, mem_array);
endtask
endmodule;
// top.v
module top;
mem m2(port lists);
initial begin
m1.init("m1_data_file.txt"); // init memory 1 with data file
m2.init("m2_data_file.txt"); // init memory 2 with data file
end
endmodule;
Hope this helps.
- Hung
    vivek_p
Is the above code synthesisable in Xilinx and Synopsys
