willcharlton
Newbie level 5
- Joined
- Mar 16, 2011
- Messages
- 8
- Helped
- 0
- Reputation
- 0
- Reaction score
- 0
- Trophy points
- 1,281
- Location
- St. Paul, MN
- Activity points
- 1,356
Hello,
I am designing a medical device that must control the flow of two gases simultaneously. The way these gases must be controlled is by maintaining a constant flow rate at the output of a device that mixes the two gases together. If the flow rate is 5 Liters/Minute then the valve controlling Gas A can allow 1 Liter/Minute while the other can allow 4 Liters/Minute, for example. Likewise, if the valve controlling Gas A can allow 2 Liters/Minute, the valve controlling Gas B can allow 3 Liters/Minute.
At present, my design achieves this control by using two, normally-closed, pwm-controlled solenoid proportional valves. By adjusting the duty ratio, we can achieve something close to this kind of control. However, the nature of this device is that Gas B rarely needs to be introduced into the mixture so Gas A is almost always at full flow rate. Subsequently, the proportional valve that controls Gas A is constantly burning 12 Watts of power which creates alot of heat and makes it very energy inefficient.
I am looking for a specific type of product that contains two valves which control the flow of gases in the same manner which I've just described. I imagine it would contain a servo motor that can be positioned to set the two valves. Does anyone know of a device such as I've described or know a way I can make one?
Here is what I had in mind. Sorry in advance for the art and penmanship...
My expertise is in electrical, not mechanical.
