Turns ratio for LLC resonant converter?
grizedale
Advanced Member level 3
Hello,
In the following article , do you agree that the "n" value in Equation 6 , page 2 SHOULD BE "NS/NP"?
https://www.fairchildsemi.com/an/AN/AN-4151.pdf
In figure 6, it says "n = NP/NS".......but this is surely wrong?
"n" is in the numerator of equation 6, page 2, and so it ABSOLUTELY MUST be "NS/NP"....do you agree?
...otherwise , gain increases with increasing primary:secondary turns ratio...which would be nonsense?
FvM
Super Moderator
Staff member
Bochum, Germany
Gain is not the primary to secondary voltage ratio of the transformer, it's the peak voltage ratio. As far as I see, all formulas in the AN are consistently using n:1 = np:ns
grizedale
i see, the thing is, i am abiding by the equations of this app note (for NON-integrated transformer) and the results are not coming out right.
When at maximum load of 80V & 4A , The Gain vs frequency curve re-shapes such that the "f0" resonant frequency corresponds to the peak of the curve........this is bad news as it means with a little bit of tolerance in the frequency , then it will be operating in the capacitive region, to the left-hand-side of the curve peak.
So something is wrong here, do you know what?
