khirat
Newbie level 2
Hey!
I want to design a microstrip patch antenna (receiver) that should operate in the frequency range of 2-18 GHz with FCC requirement of -51.3 dBm EIRP. At the same very time i want this antenna to operate only in the frequency range of 3-11 GHz with FCC requirement of -41.3 dBm EIRP while rejecting the rest of the upper and lower frequencies.
Is that possible?
Though i have designed the two antennas, operating at 2-18 GHz and 3-11 GHz, separately but i want a single antenna that fulfills my both requirements.
What should be the name given to this configuration that neither fits into dual-band (since the other band is within the first band) nor notched (since i can not actually notch the patch since then it will not operate for the other band).
Thanks in advance!
Is that possible?
Thanks in advance!
