can I use some transistor to make a simple circuit to turn on a led indication when the switch is opened? How? normally the led turned on when the swicth is close, how to do in oppasite?
I follow this circuit but it doesn't work...base voltage 12V also,I put 220K coz don't know how to calculate transistor,
my component:Q1=BC556B,
http://www.mayothi.com/images/transistor6.GIF[img]
[size=2][color=#999999]Added after 1 minutes:[/color][/size]
me_guitarist, the solution is quite simple, you will need only 1 or 2 transistors to do the job depending your demand, but I understand that it is complicated for you since you do not understand transistor.
But in my turn, I do not know how to draw a circuit on this forum, I will learn about this but it takes me time (or very appreciated if anyone can instruct me). I hope can give you the circuit and and show how to choose transistor and calculate the resistors.
h**p://www.mayothi.com/images/transistor6.GIF[img]
This design can't works!
The LED will remain ON, whatever the value of the input signal
R1=1k is efficient
R2= 47k (no more)
T1=BC556, 2N2907
The problem come from the input voltage, 5V is not enought to switch off the transistor.
The simplest way is to put a zener of 5.1V in serial with R2, the cathode connected to R2.
Sorry for expert in electronic, but this solution will work and it's easy to explain!
how to use this circuit to control magnetic lock?
I have a device which acting like a switch, built in NC & NO contact, I wanna use the NC contact & a LED as indication, when my device turn into NO, LED should lit up & release the magnetic lock.
