tuning rules for the controller- how to?
gary36
Full Member level 5
Full Member level 5
Given the system with open loop TF G(s)= K* ((1+s/z)/(1+s/p))* (1/s^2). How to tune value of k, z and p based on frequency domain specifications (such as bandwidth). Could not find a good resource (even with AI tools)
Question: The expression (1/s^2) belongs to the numerator - which means: The denominator is multiplied with s^2 ?
First question, which part of the transfer function is representing the controller (compensator), which the plant?
A possible split is type II compensator (lead-lag + integrator) and integrator plant.
Second question, what are your frequency domain specifications?
With freely tunable gain and lead-lag corner frequencies, the transfer function itself doesn't impose a bandwidth limit. It should be noted that this isn't a very realistic control system model, real systems have additional poles or true dead time.
it is lead compensator for a double integrator plant. I have represented the open loop transfer function in #1. The question is generic. Given the bandwidth specifications for this system, how to arrive at the value of k, z and p.
Bandwidth specification isn't sufficient, phase margin or control error for specific excitation is a typical control quality criterion.
An empirical approach sets lead- and lag-corner frequencies symmetrically below and above intended crossover frequency to achieve maximal phase margin and tunes k to set the frequency.
LaTeX Commands Quick-Menu:
