LandLack
Member level 3
- Joined
- Aug 8, 2013
- Messages
- 54
- Helped
- 1
- Reputation
- 2
- Reaction score
- 1
- Trophy points
- 8
- Activity points
- 526
I'm ashamed to ask these things, but I'm very inexperienced. I want to use JTOS-200 as a reference (**broken link removed**). There are 4 ports: RF out, Vcc, Vtune, ground. The output and the ground are simple, but I would like to know something about the two other ports:
1) on the "Electrical Specification" it's written that the DC operating power has: Vcc= 12V and Max_current=20mA. So I've to connect Vcc port with 12V, right? But what about the current limit, do I need to put a resistor with more than 600ohms in series with the 12V source, or something else?
2) How can I tune the voltage if I don't know about the Vtune port input resistance? I thought that I could use a simple voltage divider, but I don't know how to connect the circuit, since without the input resistance I can't determine the Vout.
Thank you for your response,
Regards,
LandLack
Regards,
LandLack
