Tube projects gallery
oldskool
Please feel free to post pix of your tube projects here:grin:
first tube amp, 6AR5/12AV6 single ended
talk about nostalgia...
later moded & replace power tube with a 6F6G, OPT with a modern Z11 cores by AT Alpha Technologies
another single ended using 13FM7 triode
oldschool point to point
when working with tubes be aware of the B+ (and the consequences8-O)
a hybrid project, gutting out a sakura SS amp, replace with an LM3886T with a 6N23P Russian tubes in a cathode follower configuration
the front end
the new look (unfinished yet)
A work in progress, pre-amp/linestage using 7193 "horny" Transmitter tubes
an EL84M/6BQ5 single ended using 12AV6 as voltage amplifiers/drivers, speaker pair is Altec-Lansing full rangers 3" 95dB in a diy bookshelf enclosure
a line amp a friend ask me to build, using 12BA6 tube pentodes
a project of my fellow diy'er & mentor, using 6L6 in a push-pull :wink:
another project of a fellow diy'er, using KT88 in parallel push-pull operation
nice collection. all those amps are your creations ?
what stops me from making tube amps everyday, is the cost of opt transformers! its a pitty to buy the kt88 for $30 and the opt to cost $150
even considering the tube as consumable , the opt is still expensive
