PrescottDan
Banned
- Joined
- May 1, 2014
- Messages
- 119
- Helped
- 0
- Reputation
- 0
- Reaction score
- 0
- Trophy points
- 16
- Activity points
- 0
What are the advantages and disadvantages to use TTL over Cmos or vise versa
Using a Transistor was a switch has what advantages and disadvantages to use a CMOS FET?
A FET as a Switch can handle a Higher positive voltage and lower Negative voltage without getting damaged?
A Transistor as a switch can be damaged with more then 5 volts on the base input? and a negative voltage of -1 volt will damage the input base
A FET can have +15 positive and negative voltage on the Gate without getting damaged?
A FET is faster at switching compared to a Transistor?
A FET has more input and output capacitance then a transistor?
TTL gates can get damaged if to high or low voltage? a CMOS gate can handle higher and lower voltages without getting damaged
A CMOS gate has more capacitance then a TTL gate? the capacitance does what?
Why would a designer use CMOS over TTL logic chips?
CMOS logic Ic chips have less "propagation delay" then TTL logic ic chips?
