TSOP2 / FBGA48 to DIP48 adapter EAGLE
fjpompeo
Advanced Member level 1
Brazil
Dear collegues,
I need an Eagle project with schematics and PCB with three footprints one FBGA48, one TSOP2-48 and one DIP48. All pin conections all make, so just don't know to put these parts in the same schematic / pcb using Eagle 7.7.0.
P.S. All pins must be present em free for conection between componentes.
Attached you will find a ready PCB locking very close the one I need.
Best regards.
Fernando J. Pompeo - Call sign PU2PLL
If you want someone else do this job then: post it in the EDA jobs section and consider to pay for the job.
If you want to do it on your own: Show us what you did so far and where the exact problem is.
Klaus
Thank you for you reply. I made a project with both FBGA and EDIP36 packages with all necessary conections but when I run autorouter it doesn't reach 100% only max 48%, what do I'm doing wrong?
  • Adapter FBGA to EDIP36-PU2PLL.zip
I don´t see any routing at all.
No autorouter setup, no DRC setup, also TSOP-2 is missing.
So I don´t see what you did, nor what is wrong.
I guess it´s an DRC setup problem.
Klaus
