tsmc epi layer option, which epi is better to prevent latchu
lionking819
Newbie level 3
san jose
epi resistance
I was told by TSMC person that they have two epi layer option to select
1. normal epi (resistance 6-8Ohm)
2. special epi (no doping, really high resistance and thinner than normal epi)
does anybody use the special epi layer before?
to prevent latchup, which one is better?
thanks
Re: tsmc epi layer option
lionking819 said:
... to prevent latchup, which one is better?
I'm not absolutely sure, but from physical reason the lower-resistance epi should be better. The higher-resistance epi layer is for HV applications ( > 5V ).
lower resistance epi is better to prevent latch-up
erik is correct.. because lower the resistance more will be current required to trigger the parasitic SCR......
