T
treez
Hello,
The TSM101A offers voltage and current regulation for an SMPS…
TSM101 datasheet
https://www.farnell.com/datasheets/1700438.pdf
However, does the current regulator opamp always take priority over the voltage regulator opamp.?
If it does not, and there is a ‘free-for-all’, then the control loops of the current and voltage loops may “fight” with each other, resulting in instability.
If there is no priority given by the chip to either its current or voltage regulation opamps, then it would only be possible to use the TSM101 as a…
1…Current regulator with overvoltage limitation
2….Voltage regulator with overcurrent limitation.
Neither of these are what we want…..we have a situation where we could have the output voltage being regulated to 24V and the output current being regulated to 5 amps simultaneously…..this could only work if one of the feedback loops (current or voltage) had a feedback loop bandwidth that was at least 10 times the other one…..and this is not viable for us.
So does the TSM101 give priority to either its voltage or current feedback opamp?
TSM101 datasheet
