Trying to use veriloga to write an edge detector
foshanno1
Newbie
Newbie level 1
So i am trying to use verilogA to write an edge detector. I can't think of a good way to do this. all i need is to trip the output whenever the input changes. I would have the cross function but the crossing threshold can change. so for example, if the input goes from 0V to 5V, I want to trip the output, but in the case when I go from -2V to -8V, I also want to trip the output. I am not sure how to do this since this requires me to keep recording the previous voltage and current voltage value? would I need a clock to do this ? Any help would appreciate it. Thanks
A design starts with requirements, a functional description, specifications.
Not only what and when it should work ... but also the limits where it should not react.
Noise comes to my mind.
Voltages, rise rates, timing....
A sketch with input signals and output signals and the according timing.
Klaus
If you have a deriv() function (and I'm prone to
assume so) then that would seem appropriate.
Amplify into clipping and put a known good
logic buffer on the back if you mean to use,
not just plot the output signal.
"Qualifying" the "edges" vs other noises /
interferers / aggressors will probably be more
of the work if you have non-ideal inputs.
The better choice might be to define the "release" voltage and current such as a 12V 20 mA relay goes to 0 mA or open circuit when released.
Then release thresholds could be >2.5 or < -5 using a dual comparator as a window detector.
Does that work for you?
You can't define an edge detector unless you define state boundaries and absolute I/O levels.
You wanted +ve edge above 0 and -ve edge below 0 but this can be defined by levels alone.
You must start by a proper spec before implementation.
I did ask you to respond to a simple solution.
RSVP
LaTeX Commands Quick-Menu:
