Trying to get Mediatomb to work on Ubuntu
Xiah
Newbie level 3
Newcastle
Hi guys i'm pretty new to ubuntu and having a slight problem when trying to run Mediatomb. I've got the below config set up and can't see anything wrong with it but whenever i try to restart it in terminal i just get {Fail} in red writing after it and has me totally stumped, is there any guru's out there who could help me? :-(
<?xml version="1.0" encoding="UTF-8"?>
<config version="1" xmlns="http://mediatomb.cc/config/1" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xsi:schemaLocation="http://mediatomb.cc/config/1 http://mediatomb.cc/config/1.xsd">
     Read /usr/share/doc/mediatomb-common/README.gz section 6 for more
     information on creating and using config.xml configration files.
  <server>
    <ui enabled="yes" show-tooltips="yes">
      <accounts enabled="no" session-timeout="30">
        <account user="fez" password="hello"/>
      </accounts>
    </ui>
    <name>fez</name>
    <udn>uuid:48b8dd9e-f2aa-4a9f-a235-d42f69492afd</udn>
    <home>/var/lib/mediatomb2</home>
    <webroot>/usr/share/mediatomb/web</webroot>
    <storage>
      <sqlite3 enabled="yes">
        <database-file>mediatomb.db</database-file>
      </sqlite3>
      <mysql enabled="no">
        <host>localhost</host>
        <username>virgin</username>
        <database>hello</database>
      </mysql>
    </storage>
    <protocolInfo extend="yes"/><!-- For PS3 support change to "yes" -->
       Uncomment the lines below to get rid of jerky avi playback on the
       DSM320 or to enable subtitles support on the DSM units
    <custom-http-headers>
      <add header="X-User-Agent: redsonic"/>
    </custom-http-headers>
    <manufacturerURL>redsonic.com</manufacturerURL>
    <modelNumber>105</modelNumber>
    <!-- Uncomment the line below if you have a Telegent TG100 -->
       <upnp-string-limit>101</upnp-string-limit>
    <extended-runtime-options>
      <ffmpegthumbnailer enabled="yes">
        <thumbnail-size>128</thumbnail-size>
        <seek-percentage>5</seek-percentage>
        <filmstrip-overlay>yes</filmstrip-overlay>
        <workaround-bugs>no</workaround-bugs>
      </ffmpegthumbnailer>
      <mark-played-items enabled="no" suppress-cds-updates="yes">
        <string mode="prepend">*</string>
      </mark-played-items>
    </extended-runtime-options>
  </server>
  <import hidden-files="no">
<filesystem-charset>UTF-8</filesystem-charset>
<scripting script-charset="UTF-8">
<common-script>/usr/share/mediatomb/js/common.js</common-script>
<playlist-script>/usr/share/mediatomb/js/playlists.js</playlist-script>
<virtual-layout type="builtin">
<import-script>/usr/share/mediatomb/js/import.js</import-script>
</virtual-layout>
</scripting>
<autoscan>
    </autoscan>
<mappings>
<extension-mimetype ignore-unknown="no">
<map from="mp3" to="audio/mpeg"/>
<map from="ogg" to="application/ogg"/>
<map from="asf" to="video/x-ms-asf"/>
<map from="asx" to="video/x-ms-asf"/>
<map from="wma" to="audio/x-ms-wma"/>
<map from="wax" to="audio/x-ms-wax"/>
<map from="wmv" to="video/x-ms-wmv"/>
<map from="wvx" to="video/x-ms-wvx"/>
<map from="wm" to="video/x-ms-wm"/>
<map from="wmx" to="video/x-ms-wmx"/>
<map from="m3u" to="audio/x-mpegurl"/>
<map from="pls" to="audio/x-scpls"/>
<map from="flv" to="video/x-flv"/>
<map from="avi" to="video/x-divx"/>
<map from="divx" to="video/x-divx"/>
<map from="mkv" to="video/x-matroska"/>
<map from="mov" to="video/quicktime"/>
<map from="qt" to="video/quicktime"/>
<map from="mpg" to="video/mpeg"/>
<map from="mpeg" to="video/mpeg"/>
<map from="rm" to="video/realmedia"/>
</extension-mimetype>
<mimetype-upnpclass>
<map from="audio/*" to="object.item.audioItem.musicTrack"/>
<map from="video/*" to="object.item.videoItem"/>
<map from="image/*" to="object.item.imageItem"/>
</mimetype-upnpclass>
<mimetype-contenttype>
<treat mimetype="audio/mpeg" as="mp3"/>
<treat mimetype="application/ogg" as="ogg"/>
<treat mimetype="audio/x-flac" as="flac"/>
<treat mimetype="image/jpeg" as="jpg"/>
<treat mimetype="audio/x-mpegurl" as="playlist"/>
<treat mimetype="audio/x-scpls" as="playlist"/>
<treat mimetype="audio/x-wav" as="pcm"/>
<treat mimetype="audio/L16" as="pcm"/>
<treat mimetype="video/x-msvideo" as="avi"/>
<treat mimetype="video/mp4" as="mp4"/>
<treat mimetype="audio/mp4" as="mp4"/>
<treat mimetype="video/x-divx" as="avi"/>
</mimetype-contenttype>
</mappings>
</import>
<transcoding enabled="yes">
<mimetype-profile-mappings>
<transcode mimetype="video/x-flv" using="vlcmpeg"/>
<transcode mimetype="application/ogg" using="vlcmpeg"/>
<transcode mimetype="application/ogg" using="oggflac2raw"/>
<transcode mimetype="audio/x-flac" using="audio-common"/>
<transcode mimetype="video/x-divx" using="video-common"/>
<transcode mimetype="video/x-matroska" using="video-common"/>
<transcode mimetype="video/quicktime" using="video-common"/>
<transcode mimetype="video/realmedia" using="mencoder-int"/>
</mimetype-profile-mappings>
<profiles>
<profile name="oggflac2raw" enabled="yes" type="external">
<mimetype>audio/L16</mimetype>
<accept-url>no</accept-url>
<first-resource>yes</first-resource>
<accept-ogg-theora>no</accept-ogg-theora>
<agent command="ogg123" arguments="-d raw -f %out %in"/>
<buffer size="1048576" chunk-size="131072" fill-size="262144"/>
</profile>
<profile name="vlcmpeg" enabled="yes" type="external">
<mimetype>video/mpeg</mimetype>
<accept-url>yes</accept-url>
<accept-ogg-theora>yes</accept-ogg-theora>
<agent command="vlc" arguments="-I dummy %in -sout #transcode{venc=ffmpeg,vcodec=mp2v,vb=4096,fps=25,aenc=ffmpeg,acodec=mpga,ab=192,samplerate=44100,channels=2}:standard{access=file,mux=ps,dst=%out} vlc:quit"/>
<buffer size="14400000" chunk-size="512000" fill-size="120000"/>
</profile>
<profile name="audio-common" enabled="yes" type="external">
<mimetype>audio/x-wav</mimetype>
<agent command="mediatomb-transcode-audio" arguments="%in %out"/>
</profile>
<profile name="video-common" enabled="yes" type="external">
<agent command="mediatomb-transcode-video-ffmpeg" arguments="%in %out"/>
<profile name="mencoder-int" enabled="yes" type="external">
        <agent command="mencoder" arguments="%in -oac lavc -ovc lavc -of mpeg -lavcopts vcodec=mpeg2video:keyint=1:vbitrate=200000:vrc_maxrate=9000:vrc_buf_size=1835 -ofps 25 -mpegopts muxrate=12000 -af lavcresample=44100 -vf harddup -o %out"/>
<buffer size="1000000" chunk-size="512000" fill-size="20480"/>
</profile>
</profile>
</profiles>
</transcoding>
