Register Log in
Trying to build rf impedance bridge.
dl09
Full Member level 4
I am planning to build a rf impedance bridge, to confirm the antenna impedance is 36.5 ohm. Could I use a digital multimeter to accurately measure the ac output of the impedance bridge?
This is a schematic.
KlausST
Super Moderator
Staff member
The answer is already given in your other threads:
No, because a DVM is not suitable for HF measurements.
Klaus
dl09
Full Member level 4
I didn't think the answer would be yes. But I can't afford a 100 mhz oscilloscope. Any alternative to accurately measure the ac output of a rf impedance bridge? The frequency is 100 mhz, I don't think it is in the audio tange.
KlausST
Super Moderator
Staff member
No, it's certainly not in the audio range. It's at about a factor of 10,000 away...
And please, if you mean Megahertz, then use "MHz", with a capital "M"
Because a lower case "m" means "milli"
And "Hz" is the unit for frequency...with a capital "H".
Repeatedly I recommend to start with basics.
My interest in electronics started abou4t 30 years ago. First as hobby, then for several years I went to school to go deepein in ekectronics, mathematics, physics. Worked in many areas of electronics, from production, assembling, developing, testing electronics.
HF never was my favourite, but I had to learn HF PCB design and all around EMI, EMC.
But still I call my HF knowledge just "rudimentaty".
What I want to say: Take your time. Start with basics. Again: Start with basics. Do courses. Random ideas don't result in progress.
Don't expect to be finished with learning within a couple of months. For sure - if you focus on HF - it won't take 30 years...
I'm still learning, that's why I'm a member of this forum.
Klaus
danadakk
Full Member level 4
dl09
Full Member level 4
will a vector network analyzer , accurately measure the voltage and current at an antenna?
danadakk
Full Member level 4
Yes, but VNA is generally speaking a low power small signal test instrument.
Basically provides Z and S Parameters of transmission systems, cable, antenna,
load.....
What accuracy are you seeking ? What power levels ? What cost do you want to
budget ?
Regards, Dana.
FvM
Super Moderator
Staff member
Bochum, Germany
VNA is the preferred tool to measure antenna impedance.
Toggle Sidebar
