Trunction in Low Pass Filter
Mina Magdy
Member level 3
Member level 3
Cairo, Egypt
hi
i am trying to design FIR Low Pass Filter with i/p 8 bits
i know that when i multiply i increase the double the bits width ex: 1111 * 1111 = 1110 0001
and when i add two numbers i increase the bits width by 1 ex: 1111+0011= 10010
my problem is : the input bits is 8 bit and the output after adding and multiplying becomes 20 bit but the next block needs only 8 bit so i want to know which 12 bit i should truncate.
Usually, you truncate the LSBs. But for your filter, it looks like you have an overall gain of 0.38 before the sum. So the 2 MSBs are never going to be set. So you can probably discard the 2 MSBs and 10 LSBs. But I would run tests first to make sure.
The question is why you scaled the coefficients as they are? With all positive coefficients, it's quite easy to go for a DC gain of 1.
For a 1x5 FIR, the easiest coefficient set to implement is [1 4 6 4 1]/16, as it requires 0 multiplers - it is all accomplished with bitshifts. Your coefficients are very close to this setup - any reason you cannot use them?
i think iwill try to choose coefficents to make the total gain 1 and using a multiple of two coefficent
thanks
but this will affect the cut off frequency
This is where experimentation comes in. Is the change in cut off frequency acceptible when you can have coefficients that use very little logic? otherwise you can just scale your origional co-efficients and take the resource hit.
