zerodegreec
Junior Member level 3
I have an amp for use with Dynamic mics being used on a system designed for Electret mics. (I had posted a question on here a few weeks ago regarding the circuit and side-tone issues.)
Here is the circuit.
I had a guy using this circuit last weekend and he said that after about 2 hours of use, the volume on speaker B became to low and static was being heard.
I have a fear and a concern.
Fear, that somehow the dynamic mic was damaged. What part of the circuit would be an area of concern. What do I need to test for in order to determine if the dynamic mic could be damaged by this circuit.
Concern is that the circuit has failed somehow. Obviously its easy to test the Cap and res but how do you test an analog amp?
I know I will need more info for you to help me, I will get what I can.
Thanks,
Thanks,
