Err404
Junior Member level 1
I am relatively new to using PICs (or any microcontrollers in anger).
I have experimented with a couple of pic16f variants using PICC lite on a PicKit2.
I think the major problem I'm having now is debouncing the signahttps://www.edaboard.com/#topl pins A and B from the (gray code) encoder.
I am trying to use the PIC's (16f628A) 'on PortB change' interrupt event.
But I could sure use some guidence right now as I can't see the wood for the trees!
//Method of detecting: (pinA:last xor pinB:current) ? 1 -> CW : 0 -> CCW
// Am trying to take care of debounce on encoder by looking for
// change back & forth, but should probably have a TMR0 timeout as well
// If it goes 10 - 11 - 10 then it's bouncing
