BrunoARG
Full Member level 4
- Joined
- Aug 15, 2014
- Messages
- 214
- Helped
- 38
- Reputation
- 76
- Reaction score
- 38
- Trophy points
- 28
- Location
- Buenos Aires, Argentina
- Activity points
- 2,177
Hello everyone.
I am spending some time in building a very simple medium-power audio amplifier I really need.
I found an about 60 or 80 watts, 30Vrms bored transformer so I decided to give it a useful application.
I bought a 50Wrms 8" 8ohm woofer (45~4500Hz) and a 4K~20K piezo-tweeter (about 6 ohm) to make some noise and their sound quality seems to be very good, but I have several questions:
The power source is an about 40V unregulated single supply, the filter I am using is performed by 4 2200uFx50V (total 8800uF). If the output power was 80W (in both heat sink and load), would it be fine? Line frequency here is 50Hz.
Should I use a high pass series capacitor with the tweeter? In the datasheet it recommends to use a series resistor but I don't want to (I had to go and buy it...). In a chart it said to use an about 6uF one.
I tested the circuit in a breadboard and it has a problem: It has a very high DC offset at the output which generates high -and really annoying- 100Hz ripple and power dissipation at the heat sink (it raises to about 80°C).
The circuit is the following:
What I changed are both amplifiers feedback resistors for 33K ones (higher gain) and feedback divider ones for 470 (almost the same). The lower cuttof frequency is about 30Hz. The resistor between one output and one feedback is 33K too.
What can be the problem? I tried changing some capacitors but the circuit started to oscillate at low frequencies as 10Hz or 3Hz with no input signal.
I don't know what to do, do you have any recommendation or solution for my problem? Maybe the inverting feedback needs some AC feedback?
Thabk you in .
EDIT: PD: I have even tried the original values but the DC output was still the same, or just a little bit lower, but it was there.
Thabk you in .
