Trouble in route-Soc Encounter
dionieco
Newbie level 6
São Paulo
I have a trouble to routing in my project using the soc encounter.
The layers not met the pins correctly.
There are pins don't have vias.
But the encounter don't show violation.
I think the problem is the LEF file.
I attach a picture for visualation the problem.
Someone have this problem?
Know how i fix this trouble??
Thank you.
natryx
Hyderabad
Why dont you check the Instance Pin box ON in your encounter and then look at the pin connections, may be the pin is in the same layer of the wire that is why its not showing any VIA in that place
thanks
natryx
