why L get large, the linearity improves? Thank you!rfsystem said:you can use the triode region of the MOS as controllable conductance. Works great for transconductance stages with ground refered input voltage. If L get longer the linearity improves. For most techs 4*Lmin works.
channel length modulation has less impact?shanmei said:why L get large, the linearity improves? Thank you!rfsystem said:you can use the triode region of the MOS as controllable conductance. Works great for transconductance stages with ground refered input voltage. If L get longer the linearity improves. For most techs 4*Lmin works.
