Triggering mosfet with opamps
deepakchikane
Full Member level 3
Full Member level 3
Mumbai, Maharashtra, India, India
Dear all..
1)i want to trigger a mosfet with the help of lm 358 op-amp
problems,
a)lm 358 is having 50ma sourcing current capability but my irf 730 needs atleast 2 amp peak gate current..
How i can get 2 amp from 50 ma..
If u have any circuits,idea or any designs,please explains
my brain is not working..
Plz plz plz
You need stiff current drive for hard switching, but if this
is an analog function (closed loop follower, or some such)
I recommend that you turn the limitation into a virtue,
put your frequency compensation at the weak node
(perhaps using an uncompensated or non-unity-gain-
stable op amp to recoup some bandwidth and simplify
the comp / stability). But you also should make some
effort to ensure that the FET is actually capable of
operating in high-dissipation regions continuously, if
continuous analog operation is your application. Some
FETs aren't good for linear operation.
