philba
Full Member level 2
opto driver
I am designing a project that will use a triac to control a resistive load (fuser from a laser printer), for isolation, I plan to use a moc30xx (probably moc3032) to drive the triac.
Here is an example of the kind of circuit I will use:
My question is on sizing the 180 ohm resistor (from "hot" to pin 6). I haven't figured out how much current will flow. If I use ohms law blindly, it comes out huge yet I've seen projects that use 1/2W resistors for this application so I must be missing something. How do I calculate the actual current through the resistor in order to size it properly?
note, I have looked at a number of datasheets for this class of parts and looked at lots of tutorials but have found nothing on this point.
thanks for any help.
Phil
Phil
