siongboon
Advanced Member level 1
I have duplicate quite a number of triac circuit before.
The recent one I did behavior not quite what I expected.
I have attached the schematic.
What I did is that I added the indicator circuit on the right side,
to indicate if there is AC power at the output.
When connected, I observe a weak lighting up.
I then measure the output which reads about 120Vac.
My AC mains voltage is 230Vac.
I have change a number of new triacs and opto-triac IC.
The fault is the same.
Then I found out the if both the capacitor is removed,
the problem is resolved.
If I add the cap, I cannot put the indicator.
If I put the indicator, I have to remove away the cap.
I am still figuring out why.
Hope that you can advise me on this issue.
I have also tried another indicator lamp that I purchase.
The lamp has a resistor integrated inside.
When connected, the behavior is the same.
Thank you for the help.
Attached is the schematic.
