I have a 2 port/4 terminal transmission line with characteristic impedance Z0. Input Port is I+/I- and Output Port is O+/O-.
When doing impedance matching, I understand you can put an input resistor Rs=Z0 and make RL=Z0 between O+/O-.
But throughout the transmission line I have loads on it as well, say B+/B-, C+/C-, etc. I have to believe that this situation is common in high frequency RF signal distribution with multiple
"taps" along the way.
If the loads are, say, capacitive, such as driving transistor gates, how do you "account" for them in terms of overall transmission line and impedance matching? Do you put in some matching resistors along those taps?
Also what if there are resistive loads along the transmission line, what effect would that have on the overall transmission line?
Is this basically where you need to go deeper with multi-port s-parameter type analysis (which I am weak in, admittedly).
Any insight on how to deal with this is appreciated!
