Transmission Line Transformer Balun
ge
Full Member level 5
Pennsylvania, USA
1) Could someone suggest a reference to more detailed explain a balun? I'm reading through Jerry Sevick's book Transmission Line Transformers. On page 1-4, he says "By connecting a ground to terminal 5, a negative potential gradient -(V1-V2/2) is established from terminal 3 to 4 and -V2/2 from terminal 1 to 2.
This is likely true, but why is it true?
2) At the bottom of page 1-4, Boot-Strap. What is meant by "Boot-Strap"?
I don't know about any of these questions, but "Marchand balun"
found me a lot of realted stuff back when I was looking for it.
I need to keep reading.
Agreed. I think the book is pretty clear.
The term has different meanings in electronics. Here it's about connecting a voltage source on top of another voltage to increase the voltage level.
Reactions: ge
    ge
The analysis is quite simple. If the node 5 is conneccted to ground, the voltage V45=V52=V2/2
From KVL: V31=V34+V45, where node 1 is connected to ground, then
V34=V1-V2/2
SInce node 1 is connected to ground, then: V21=V2/2
About the bootstrapping, it's a method to rise the output voltage by adding some of the input voltage. See:
Reactions: ge
    ge
V34=V1-V2/2
Hi albbg,
Thanks for the reply.
V45=V52=V2/2
I'm good with that.
Where did the drops V52 and V21 go? ... oops, I now see. "Both" V1 and V5 is grounded.
LaTeX Commands Quick-Menu:
