[SOLVED] Transmission Gate Delay
Engineer4ever
Member level 3
Member level 3
I am designing a PFD/CP/LF in a PLL loop. I need to connect the PFD output to the CP input, but my CP has two inputs; UP and UP-bar and the same for DOWN signal. The delay between UP and UP-bar is one inverter delay, so the UP-bar signal leads the UP signal by a delay of one inverter but I need both signals to arrive at the CP input at the same time so I need to pass the UP-bar by a transmission gate with the same delay of the inverter. My question is, how to determine the transmission gate delay? Is there an equation for it?
Note: I am working on 65nm technology in case that matters.
Thanks in advance,
Hi.
I know how to solve delay problem because of inverter delay.
Using 'latch-buffer', I solved the problem.
It can make the UP-bar & UP signal without delay. (same Down signal)
good for you!
regards,
