Tybi
Newbie level 5
how can I design a good transition from a SMA endlaunch to a microstrip line? I designed a pcb and used the recomended footprint (from the datasheet) of the SMA endlauch. The width of the pad of the signal pin was bigger than the width of the microstrip line. So a made a tapered transition. When I measured a simple through connection with two SMA endlauches and the microstrip line I get a horrible matching.
Here are my suggestions what could solve the problem:
- make the width of the pad of the signal pin the width of the microstrip line
- make a tapered cut out in the ground plane
By the way: do I have to solder the SMA endlaunch to the top AND the bottom ground plane of the pcb?
