Transistors cross reference
jazzz
Member level 1
Member level 1
EU
russian transistors cross reference
Hi, can u tell me some equivalent for
2SK1530, 2SJ201 and 2SK537.
Thanks
jazzz
Member level 1
Member level 1
EU
2sk1530 equivalent
Nobody knows?
cyber1
Member level 4
Member level 4
pakistan karachi
equivalent of 2SK537
buz50
2sk1199
2sk1338
    jazzz
nguyennam
Advanced Member level 1
If you have datasheets of these transistors as well as the circuits using them, so you can easily know which transistors can be used to replace.
Sometimes it is hard to find out this kind of cross table, on the other hand, they usually show 1 or 2 equivalent transistors only, and in many cases, you cannot find out those equivalent in your market.
So, try to research the datasheets, the circuits (voltage, current, frequency, ... used), local market, and you can find out what you want.
When I began to learn electronics, I tried to collect that kind of document either, and then I quickly found out that they are really useless.
nguyennam.
