DatsAbk
Member level 3
Hello People...
I'm messed up with transistor switching using PIC18f4550.
I need to generate variable spikes by applying PWM signal at the base.
The collector voltage is set to be 12V and obviously base voltage will be 5V.Which transistor and which values of base resistor and collector resistor should i use?
These are the few available options with me:
2N2222
2N3904
BC547
2N2222
2N3904
BC547
