SBlevins
Newbie level 2
- Joined
- May 5, 2013
- Messages
- 2
- Helped
- 0
- Reputation
- 0
- Reaction score
- 0
- Trophy points
- 1,281
- Activity points
- 1,306
Hi guys, I have searched forums to no avail, so I figured maybe you could help. (I am an absolute novice)
I have two wires which have DC current flowing through them. One has 5V DC at 500mA, and the other ranges from 10mV to 3.3V with a small varying current. The current has to flow in two directions for that second wire which is hooked up to something that is transmitting data over it, but I also need it to be turned on by that first wire. The data transmitted must be very finicky because I tried to test the current while there was data transfer using a multi-meter and the connected devices said there was not a connection.
I have been told that a TRIAC would work, as all I need is for the circuit to turn on once the first wire is active, and it will turn off once unplugged. I was hoping to allow free flowing current through the second wire, and have it activated by the 5V wire, but only minutely. And by this I mean that 5V still has to connect to a peripheral device which has to be driven by that 5V source.
I have looked at transistors and have no idea how to make sense of the datasheets. I attempted to use a relay, but to no avail. I think I may need a voltage regulator.
If you guys could direct me to a transistor/part/component which would work that would be great. Unfortunately I am kind of restricted to RadioShack or local electronics stores at the moment. I am in over my head with this project, and I did not expect it to involve additional electronics.
Thanks,
-Sterling
Thanks,
-Sterling
