transistor fingers - transconductance layout
HBK
Member level 2
+gate +resistance +fingers
In some articles have explained that large transistor's width can be divided in to number of fingers but it should be less than
N <(1/5-1/10)1/gm
where n is no. of fingers.could anyone pls.explain me how the transconductance is related to the fingers of the transistors.
Look in Razavi's "Design of analog CMOS integrated circuits" page 635. The idea is to make the termal noise from the gate resistance of the finger smaller than the transistors noise reflected to the gate.
But in P635,
"In low-noise applications,the gate resistance must be 1/5 to 1/10 of 1/gm".
It is "gate resistance",not "no. of fingers".
So who is wrong?
these are related. If you one finger for a transistor W/L, then the gate resistance is (W/L)*Rpoly - where Rpoly is the sheet resistance of the material. If you now make the same transistor with n fingers, you have gate resistance of (W/nL)*Rpoly, simply because you get the fingers connected in paralel.
If I'm no mistaken...
Using multi-finger tends to give bigger paracitic capacitance...
Is it true? 8O
It should be less parastic capacitor, because the drain and source can share.
Another arguement to this (something designers often forget) is that very large transistors are never characterised properly in the models. Fabs will typically characterise out to about 20um width then extrapolate the performance in Spice (the test chips for characterisation rarely go larger than this). The model is very often incorrect at large L or W, so if you design the input to an op amp with 40um or something, the gain may be a lot lower than you think and cause offsets to appear that look like mis matching.
Also, any slight Vt shifts from metallisation processes will hit larger devices (larger antenna's to pick up charges) so matching issues can occur also.
Multi fingered devices are better where possible.
Yes, when we use the inverse ratio MOS(W<<L) or large ratio(w>>L), we often use several transistor series which every transistor w and L all meet the model max. and min. W and L to guarantee the model accuracy.
normally,
we say that the resistance of each finger should not be greater than the inverse of its transconductance.
this is because of gain issue.
