transistor current input from OPAMP
flipper_md
Junior Member level 2
Hello all
I've built this motion detection circuit and it work fine,
but I want to add a status led hooked directly after the two diodes and I dunno how to calculate current there for a transistor and the correct resistor to get it saturated?..
all I know is that voltage is 3.2 or 0 volts...
Is there a way to physically measure these things or it has to be computed/simulated?
thanks[/img]
To drive an LED you need roughly 10mA (btw. you need a current limiting resistor in series with LED - see attached picture)) ..
An average NPN BJT has the gain of no less than 100, so:
10mA/100 =>01.mA – that’s the Base current ..
[3.2V – 0.65V]/0.1mA => 25.5kohm
0.65 represent the Ube voltage below which the transistor is “OFF” ..
To make sure that the transistor is going to be “saturated” – “ON”, choose a resistor below 25.5k, and anything between 10k and 20k would be a reasonable choice ..
IanP
:D
thanks for the fast reply Ian!
I assume a 2N3904 would be fine?
where do the 0.65 Ube come from? is it the same as Vce on this spec sheet?
so I could recalculte using 1.0V...
no worry for the LED, I've burned enought of these to know they like to hang beside a resistor :)
V[ce] is the Collector-Emitter voltage ..
I'm talkig abot U[be]: Base-Emitter - look at the very bottom of the table that you provided in your post - U[be]sat ..
IanP
:D
Oh right there in my face LOL
thanks!
