Transistor base at high voltage
BradtheRad
Super Moderator
Staff member
Minneapolis, Minnesota, USA
What about the scnerio when 9V is not connected. I need a low at MCU pin. Shouldnt I be using a 100nF cap at output so that it is low when no load in connected.
A capacitor may smooth spike-y behavior somewhat, but that is not an essential role in what you're doing.
If you wish, you can install a 'bleeder' resistor, which will instantly pull the input wire to 0V when no voltage is applied. The bleeder resistance can be several k-ohms.
When no load is connected, the led's get 22mA. That is too much unless you increase the input resistor.
You need to decide regarding which pieces of equipment are to be detachable from your circuit.
tiwari.sachin
Full Member level 6
India
I am using circuit as below
9V is detachable. When attached would it not become a voltage divider
Note: The MCU Input has to be 3.3V
KlausST
Super Moderator
Staff member
i wonder why the low ohmic 250 Ohms.
Is it for a power supply, or a logic signal only?
Klaus
KlausST
Super Moderator
Staff member
then both resistors = 10k should do.
The 100n then gives a delay of about 1ms. Adjust it like you want.
Klaus
