Is it necessary to use the inverting input of the voltage feedback amplifier (VFA) to amplify the photocurrent signal from a photodiode? Can we use the noninverting input configuration of the VFA?
Of course, you can. As you said: ...but using a negative feedback.
This means: negative feedback to the non-inv. input by using an additional inverter (sign change) within this feedback loop. But I don`t know if this was your idea behind the question.
LvW
You could, but then it wouldn't be a transimpedance amplifier - it would be a voltage amplifier. Maybe if you showed what you had in mind I could explain better.
