I is known, so it is a question of P and R..Again, what is value for resistor which can resist 500 mA of current.
No.Is my calculations are right..??
Again calculation for Resistor value i didnt understand..??
P = I^2 * R --> P = 0.25 A^2 * R
Faults in the post #1 calculation are:Guys..
I need calculations for how to calculate it..
i have given all the Terms..??
Where i am getting wrong..??
How do you expect AC current to go through the capacitor with the diode in series ?????????the diode is at the wrong place. --> it won´t work.
Can you explain why the circuit in #5 not working ?????????
Means what? Capacitor values have been previously calculated in this thread.i want to use the exact capacitors
Do you see any Y2 type with capacitance in the 10 µF range? No. So why are you mentioning Y2?I have many Capacitors like X2/Y2
What will be name Type of Capacitors..
mkp..?? polyproplene..??
