[SOLVED] Transformer saturation & ACM control
F
fourtytwo
This has nothing to do with LEDS
Many power converters are liable to saturate the transformer under unbalanced conditions, I am looking at a full bridge with a bridge rectifier output so there are plenty of oppertunities! The standard method to reduce the problem is to use peak current control. In my case I wish to use average current mode, a typical LPF plot for a 25Khz converter is shown in the attachment (this is currently (pun) running a half bridge). What I am having trouble getting my head around is given the LPF somewhat inhibits cycle by cycle current limit will ACM still prevent flux-walking and potential saturation ?
BTW the target is 3Kw through an ETD54 at 50Khz
PS I dont mean to be asking a yes/no question, rather has anybody working knowlage in this area they care to share ?
  • EA_AC.pdf
If the LPF cutoff frequency is lower than the reciprocal of a half period, I would say that ACM would not reliably prevent assymetrical core saturation.
Think of one situation. Let's say, as an example, that when you power-off the converter, you leave core saturated in the B- direction.
If the next time you power up the converter the bridge starts in a way to impress additional B- flux, the core will saturate.
Yes unfortunatly you confirm my feelings, the reason I am using ACM is to prevent instability due to a downstream LCL filter.
Have to get the thinking cap on.....how about capacitors in series with the primary ?
Actually TBH I think I had better get the simulator out again and take a closer look though this is a very very very slow process (no access to supercomputer)!
I'm not sure I understand the whole picture but generally the modulator of a full bridge should be inherently balanced. Residual DC offset voltage in the switching waveform will be minimal. Average current mode control typically has plenty of bandwidth (>1/10th Fsw I expect) and should have no problem dealing with that residual DC offset during operation. Startup may be a little unique but still I expect average current mode control to get control in some small number of cycles.
I agree asdf44 but of course in the real world imbalances creep in, I guess it's a question of if those imbalances are suficient to eat up the reserve flux density. ACM has low bandwidth relative to Fs so I agree with schmitt it is unlikely to help. Instead I have spent some time trying to model my transformer primary & core as a saturateable reactor in LTspice, I think I have suceeded and by deliberatly inducing imbalance (by differential on times) can indeed induce saturation. I have compared the situation with & without a primary series capacitance and with defenitly reduces the severity of saturation as shown in red on the picture below, green is DC coupled.
View attachment saturatable ind_trafo1.pdf
Seems unlikely you will get 3kW continuous through an ETD54 at 50kHz - what is your calc Bpk under these conditions? Usual way to stop flux walking is a suitably sized DC blocking cap in series with pri ...
At 3 kW, LLC or at least series LC resonant converter would be preferred for lower switching loss and EMI. In this topology, the series capacitor will already provide DC balancing.
Re: Transformer saturation & ACM control
According to ExcellentIT7100 0.144T @ 2882W. And yes I wondered if I could do without the caps moving from a half to a full bridge but I think the answer is clearly not.
Ahh yes whilst I agree I have some peculiar reason for using hard switching, this converter is modulated and has to work dynamically over a huge power ratio, I am simply not sure a resonant job could maintain resonance and linearity. Good and tight layout minimizes EMI in my experience.
And thank you everybody for your comments you have been very helpful indeed
