Register Log in
Transformer coupled Class A amplifier
paulmdrdo
Full Member level 3
Hi Guys! I'm having some kind of difficulty understanding how the voltage VCE of a transformer coupled class A amp can theoretically swing from 0V to 2Vcc. In class I learned that it was due lenz's law. But I'm still having a hard time to picture it. Please help me.
2020-05-25 20_07_03-transistors - Twice Vcc in transformer coupled Class A amplifier AC load lin.png
BradtheRad
Super Moderator
Staff member
Minneapolis, Minnesota, USA
When you turn on the transistor fully, it provides a low-resistance path to a supply rail, causing that supply rail to influence the output.
When you turn off the transistor, it is high resistance, allowing the opposite supply rail to influence the output.
schmitt trigger
Advanced Member level 5
I had some spare time (Thanks COVID-19) and breadboarded a 2N3904 single ended class-A amplifier with an audio transformer load on the collector.
Indeed, the collector voltage exceeds B+, as shown in the attached scope waveforms.
The pink trace is the supply voltage (9v), the blue is the emitter voltage which bounds the lower swing, and the yellow is the collector voltage which goes above and below the battery voltage.
Transistor biasing is not optimized, and that is the reason the waveform will clip on the negative excursion and thus the full peak to peak excursion wasn't realized.
paulmdrdo
Full Member level 3
HOw is the VCE able to vary from 0V to twice of the supply voltage?
Yes I know that would happen but my question is hOw is the VCE able to vary from 0V to twice of the supply voltage?
BradtheRad
Super Moderator
Staff member
Does your single-ended amplifier have a capacitor somewhere in the output stage? If combined with an inductor (or transformer), then it's possible for LC resonant action to generate unexpected large voltage swings... particularly if no load is attached.
Easy peasy
Melbourne
No - it is just the fact that once the xtor has turned on, i.e. output goes low, you have stored an amount of energy in the xfmr core, now if the xtor is turned off above a certain rate its o/p can go higher than the rail - thanks to the stored energy - this only works above a certain freq - if you do it too slowly you don't get this effect.
this is poorly explained in just about every text book.
Toggle Sidebar
Design Fast
