djjoni2
Hey guys a transformer of mine broke (primary winding). So i got it rewound with same number of turns and diameter of wire (790 and 0,35 mm). The traf was rated at 13.5 volts and was pumping out 14.5. Soo now it is at 15.5 v. Im using it to power a sound system creative - t6100 rms wattage 76w total and the woofer is 26w. Do you think that i should unwind some of the wire or just use it. I know that amplifiers use a wide range of voltages. Thanks.
