sztibi82
Full Member level 3
Hi To all
I would like to implement a controller on a PIC32 microcontroller
Sadly i dont know why, the putput is 255 or 0, rarelly i can get a signal between them
Please could someone more experienced tell me what should i change
Thank you
Thank you
#include <plib.h>
// Configuration Bit settings
// SYSCLK = 72 MHz (8MHz Crystal/ FPLLIDIV * FPLLMUL / FPLLODIV)
// PBCLK = 36 MHz
// Primary Osc w/PLL (XT+,HS+,EC+PLL)
// WDT OFF
// Other options are don't care
#pragma config FPLLMUL = MUL_18, FPLLIDIV = DIV_2, FPLLODIV = DIV_1, FWDTEN = OFF
#pragma config POSCMOD = HS, FNOSC = PRIPLL, FPBDIV = DIV_2
// Let compile time pre-processor calculate the PR1 (period)
#define FOSC 72E6
#define PB_DIV 8
#define PRESCALE 256
#define TOGGLES_PER_SEC 15000
#define T1_TICK (FOSC/PB_DIV/PRESCALE/TOGGLES_PER_SEC)
unsigned int feedback; // conversion result as read from result buffer
unsigned int reference;
double ref;
double fed;
double result;
unsigned int offset;
unsigned int loop;
double y_0;
double y_1;
double y_2;
double y_3;
double y_4;
double y_5;
double y_6;
double y_7;
double u_0;
double u_1;
double u_2;
double u_3;
double u_4;
double u_5;
double u_6;
double b_0;
double b_1;
double b_2;
double b_3;
double b_4;
double b_5;
double a_0;
double a_1;
double a_2;
double a_3;
double a_4;
double a_5;
double y_;
int main(void)
//STEP 1. Configure cache, wait states and peripheral bus clock
// Configure the device for maximum performance.
// This macro sets flash wait states, PBCLK divider and DRM wait states based on the specified
// clock frequency. It also turns on the cache mode if avaialble.
// Based on the current frequency, the PBCLK divider will be set at 1:2. This knoweldge
// is required to correctly set UART baud rate, timer reload value and other time sensitive
// setting.
SYSTEMConfigPerformance(FOSC);
CloseADC10();
// Override PBDIV to 1:8 for this timer example
mOSCSetPBDIV(OSC_PB_DIV_8);
#define PARAM1 ADC_MODULE_ON | ADC_FORMAT_INTG | ADC_CLK_AUTO | ADC_AUTO_SAMPLING_ON
#define PARAM2 ADC_VREF_AVDD_AVSS | ADC_OFFSET_CAL_DISABLE | ADC_SCAN_OFF | ADC_SAMPLES_PER_INT_2 | ADC_ALT_BUF_ON | ADC_ALT_INPUT_ON
#define PARAM3 ADC_CONV_CLK_INTERNAL_RC | ADC_SAMPLE_TIME_15
#define PARAM4 SKIP_SCAN_ALL
#define PARAM5 ENABLE_AN3_ANA | ENABLE_AN4_ANA
SetChanADC10( ADC_CH0_NEG_SAMPLEB_NVREF | ADC_CH0_POS_SAMPLEB_AN3 | ADC_CH0_NEG_SAMPLEA_NVREF | ADC_CH0_POS_SAMPLEA_AN4 );
OpenADC10( PARAM1, PARAM2, PARAM3, PARAM4, PARAM5 ); // configure ADC using parameter define above
EnableADC10(); // Enable the ADC
while ( ! mAD1GetIntFlag() ) { }
// STEP 2. configure Timer 1 using internal clock, 1:256 prescale
OpenTimer1(T1_ON | T1_SOURCE_INT | T1_PS_1_256, T1_TICK);
// set up the timer interrupt with a priority of 2
ConfigIntTimer1(T1_INT_ON | T1_INT_PRIOR_2);
// enable multi-vector interrupts
INTEnableSystemMultiVectoredInt();
// configure PORTD.RD0 = output
mPORTESetPinsDigitalOut(BIT_0);
mPORTESetPinsDigitalOut(BIT_1);
mPORTESetPinsDigitalOut(BIT_2);
mPORTESetPinsDigitalOut(BIT_3);
mPORTESetPinsDigitalOut(BIT_4);
mPORTESetPinsDigitalOut(BIT_5);
mPORTESetPinsDigitalOut(BIT_6);
mPORTESetPinsDigitalOut(BIT_7);
mPORTESetPinsDigitalOut(BIT_8);
mPORTESetPinsDigitalOut(BIT_9);
mPORTESetPinsDigitalOut(BIT_10);
mPORTESetPinsDigitalOut(BIT_11);
mPORTESetPinsDigitalOut(BIT_12);
mPORTESetPinsDigitalOut(BIT_13);
mPORTESetPinsDigitalOut(BIT_14);
mPORTESetPinsDigitalOut(BIT_15);
mPORTDSetPinsDigitalOut(BIT_0);
mPORTDSetPinsDigitalOut(BIT_1);
y_7=0;
y_6=0;
y_5=0;
y_4=0;
y_3=0;
y_2=0;
y_1=0;
y_0=0;
u_6=0;
u_5=0;
u_4=0;
u_3=0;
u_2=0;
u_1=0;
u_0=0;
// Regulator Transfer Function
// b_5 b_4 b_3 b_2 b_1 b_0
// 1 a_5 a_4 a_3 a_2 a_1 a_0
b_5=-215.780080326155;
b_4=477.218796789085;
b_3=-396.523257805262;
b_2=169.140604103785;
b_1=-38.3294099942858;
b_0=3.69959246124159;
a_5=-2.23588994487889;
a_4=1.86997977823815;
a_3=-0.797246753084504;
a_2=0.180235639535461;
a_1=-0.0170776862076544;
a_0=7.07044425739722e-11;
a_5=-a_5;
a_4=-a_4;
a_3=-a_3;
a_2=-a_2;
a_1=-a_1;
a_0=-a_0;
while(1);
void __ISR(_TIMER_1_VECTOR, ipl2) Timer1Handler(void)
mT1ClearIntFlag();
offset = 8 * ((~ReadActiveBufferADC10() & 0x01)); // determine which buffer is idle and create an offset
feedback = ReadADC10(offset); //intrarea
reference= ReadADC10(offset+1); // iesirea
ref=(double)reference/8;
fed=((double)feedback-80)/8;
u_6=(ref-fed);
y_=-a_5*y_5-a_4*y_4-a_3*y_3-a_2*y_2-a_1*y_1-a_0*y_0+b_5*u_5+b_4*u_4+b_3*u_3+b_2*u_2+b_1*u_1+b_0*u_0;
y_6=y_/4;
y_0=y_1;
y_1=y_2;
y_2=y_3;
y_3=y_4;
y_4=y_5;
y_5=y_6;
u_0=u_1;
u_1=u_2;
u_2=u_3;
u_3=u_4;
u_4=u_5;
u_5=u_6;
PORTE=255-(unsigned char)(y_6);
//mPORTEToggleBits(BIT_7);
