[SOLVED] Transceiver module help?
ChansAlive
Member level 3
Member level 3
Hi
I want to interface a microcontroller(PIC33F) with ECU of a vehicle using K-Line communication. Can someone suggest me a transceiver module for interfacing. The basic requirement for a K-Line communication interface is an UART. But in automotive application it requires a transceiver module which will be fault tolerant as well... There are LIN transceiver available. LIN is also running above UART protocol except for a sync break. But I don't know the LIN transceiver will be compatible with K-Line...
Hope someone will know this...
TI/National offer a line of LIN 2.x/SAEJ2602 Physical Interfaces/Transceivers which also support K-Line (ISO9141):
SN65HVDA100 Datasheet
TPIC1021A Datasheet
NXP offers several transceivers compatible with both protocols:
Infineon offers transceivers compatible with both protocols:
The Microchip Document, Migrating Designs from MCP201 to MCP2021-500, states:
Note:
The MCP2021/2/3/4 family of devices
support both LIN and K-line (ISO-9141)
buses, 5.0V and 3.3V system voltages,
and a new RESET output.
Microchip LIN Transceiver Products
STM and Freescale both offer K-Line (ISO9141) Compliant Transceivers as well.
BigDog
@BigDog, @tpetar,
Thanks for the post... It did solve my question... Thanks both of you for the help...
