xuedashun
Member level 1
I designed a 2-1 sigma-delta modulator and found fft issue I don't understand. My sim has 2 steps:
1) run "tran" analysis in spectre (select "Transient Noise" option)
2) read data from modulator output to matlab and do fft in matlab
I used 2 different sampling capacitors (1pF, 4pF) for the first integrator and other parameter (fclk, fsample, Nfft=8192, OSR...) are all same.
I use the tran analysis in cadence and select the "Transient Noise" option, the "Noise fmax" is set to 50*fclk. I think this option will take the device noise into account in simulation. But the results are confusing, the 2 different sampling capacitors (1pF and 4pF) do NOT have significant difference on the fft plots and the SNR values only have 2dB difference.
Could anyone give me some suggestions or explain this for me? Thank you!
